Enabling WTUser to select member in Workflow
Sriram_Rammohan
Hello All,
I am trying to assign a WF Task to my User,where he can select some members from a group (GRP1) to whom the next task is assigned.
In the WF Activity block under Role setup tab,WTUser is my participant and GRP1 is my role group.I am enabling View,Add and Remove access to my WTUser for the GRP1.After completion of this ,when I launch my WF,it works successfully.
But when I import my exported WF xml again ,the check boxes where I enabled the View /Add and Remove are disabled.This behaviour is strange.Due to this my User is not able to select members and WF is halted.
Can you suggest a solution for this.
Sriram
0 REPLIES 0
