Currently only internal users using Windchill application. We are planning to give access to External Users through B2B setup. Hence I enabled SSO. Also I enabled Basic authentication for local ldap users.
After this Creo View , Windchill Server registration in Creo and WGM(Solid works) not working for basic authentication URL - https://<server>/basicLogin.html
Any advise?
Thanks in advance
How did you enable single sign on? How did you enable basic auth for local users only?
Any pertinent errors from the MS log?
@jbailey - It works for Server registration with Creo and Solid works now for local users by doing the authentication first in the embedded browser and then registering server helps as workaround. But still Creo View is not working , no error in MS logs , but when we open Creo View it shows 'Must authenticate Client using the same authenticated Windchill User'.
