Enforce Line Numbers Preference
AP_10483126
Version: Windchill 13.0
Use Case: When the preference Enforce Line Numbers is set to NO and in the DT the attribute Publish Line Numbers for Components in an Assembly when Publishing a BOM: is set to YES. Even if a line number is blank in the BOM it throws an error in ESI.
Description:
When the preference
There is lots of notes around this topic. Please review the following since there is just a log of infromation. Post the exact error you are seeing.
https://www.ptc.com/en/support/article/CS35247?source=search
https://www.ptc.com/en/support/article/CS334701?source=search
https://www.ptc.com/en/support/article/CS439976?source=search
