Error After Completing Rehost
borourke
11-Garnet
To set up our 2nd test migration from 8.0 M040 to 9.1 M040, I am getting the following error when I try to start up 8.0 M040 after finishing up the import of the LDAP and Oracle database:
Unable to start manager: "wt.audit.AuditService" with implementation class: "wt.audit.StandardAuditService"
All help is most appreciated!
Send lawyers, guns, and money...the sh!t has hit the fan!
Check whether all the database tables exist.
On Sat, Feb 27, 2010 at 2:13 AM, Bill O'Rourke
> *Send lawyers, guns, and money...the sh!t has hit the fan! *
sauls
(To:borourke)
Bill,
How did you guide yourself through rehosting procedure?
The PTC rehost guide does not always covers all.
1) i suggest to install apache and then to configure it propperly (there is
an ant script that reconfigures apache from Windchill AppacheConf/config)
2) in the Windchill bin InfoEngine directory there aresome bat files that
does not point correctly
3) Look in the LDAP config nodes in the properties of the nodes (specially
Ldap and EnterpriseLdap) that arenot correctly pointed to the new
installation by the PTC supplied script
Try those, and i hope you will succeed
Saul
On Fri, Feb 26, 2010 at 10:43 PM, Bill O'Rourke
