In my dev environment, I made some changes to one of our workflows, validated the changes and then went to export to move it to our next environment. When i clicked the export from the Workflow Admin applet, I supplied the name and location and then received an error, see MS log excepert.
Any insight would be greatly appreciated. I don't want to manually redo the changes in the next environment.
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: IXBExpImpStatus: addMessage size=0, s=<started export=" for=" chosen=" objects...=">
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: IXBExpImpStatus: addMessage size=1, s=<chose 1=" objects=" that=" are=" candidates=" for=" export=" (the=" number=" of=" really=" exported=" objects=" can=" be=" less)=">
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: IXBExpImpStatus: addMessage size=2, s=<now exporting=" object:=" workflow=" template=" -=" g&i=" variance=" workflow...=">
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: wt.fv.FvFileDoesNotExist
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.fv.contentmover.LocalVaultItem.getStoredItemFile(LocalVaultItem.java:376)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.fv.contentmover.LocalVaultItem.retrieveStream(LocalVaultItem.java:183)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.fv.StoredItem.retrieveStreamCommon(StoredItem.java:688)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.fv.FvItem.retrieveStream(FvItem.java:505)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.workflow.definer.WfExportImportHandler.addProcessOverview(WfExportImportHandler.java:1783)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.workflow.definer.WfExportImportHandler.addRelatedObjectInfo(WfExportImportHandler.java:831)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.workflow.definer.WfExportImportHandler.stringWfProcessTemplate(WfExportImportHandler.java:412)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.workflow.definer.WfExportImportHandler.exportTemplateAsStringBuffer(WfExportImportHandler.java:2008)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.workflow.definer.WfDefinerHelper.exportTemplateAsCsvStringBuffer(WfDefinerHelper.java:227)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.ixb.handlers.netmarkets.WfTemplateExporter.exportObject(WfTemplateExporter.java:47)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.ixb.publicforapps.Exporter.doExport(Exporter.java:270)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.ixb.publicforapps.Exporter.doExport(Exporter.java:232)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.ixb.publicforapps.Exporter.doExport(Exporter.java:212)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.ixb.clientAccess.StandardIXBService.exportObjects(StandardIXBService.java:1133)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.ixb.clientAccess.IXBServiceFwd.exportObjects(IXBServiceFwd.java:975)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.clients.workflow.definer.Server.exportObjects(Server.java:285)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at java.lang.reflect.Method.invoke(Method.java:597)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.method.MethodResultWriter.writeExternal(MethodResultWriter.java:151)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at wt.method.MethodResult.writeExternal(MethodResult.java:226)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at java.io.ObjectOutputStream.writeExternalData(ObjectOutputStream.java:1418)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1390)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1150)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:326)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at sun.rmi.server.UnicastRef.marshalValue(UnicastRef.java:274)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:315)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at sun.rmi.transport.Transport$1.run(Transport.java:159)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at java.security.AccessController.doPrivileged(Native Method)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: at java.lang.Thread.run(Thread.java:619)
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: IXBExpImpStatus: addMessage size=3, s=<exception: "null"=">
Fri 8/19/11 22:05:19: RMI TCP Connection(23)-10.70.90.38: IXBExpImpStatus: addMessage size=4, s=<unexpected problem=" in=" export=" import=" process.=">
This did the trick! Thank you!!!!
