When I do an Import of the database Oracle 11.2.0.3 (Windchill 10.1 M020) when Roehosting, I get this error message :
ORA-39083
CREATE UNIQUE INDEX "WCHILL"."WTDOCUMENT$UNIQUE50" ON "WCHILL"."WTDOCUMENT" ("ID
A3MASTERREFERENCE", "VERSIONIDA2VERSIONINFO", "ITERATIONIDA2ITERATIONINFO", "WCH
ILL"."WIPPK"."GETNORMALIZEDWIPSTATE"("STATECHECKOUTINFO"), "ONEOFFVERSIONIDA2ONE
OFFVERSI") PCTFREE 10 INITRANS 2 MAXTRANS
I execute this command :
impdp xx/xx@target dumpfile=WTSCHEMA.DMP directory=directory SCHEMAS=source_schema logfile=imp.log
Does anyone an idea how to solve this problem ?
I would like to see logfile=imp.log to see it's progress. If it's not proceeding because of the above index then it needs to create that to WCHILL database. If it's already moved on than just need to place the missing index to the target database.
I know that when we are rehosting we have a number of indexes that cannot be created, because the schema name is kept.
Is WCHILL the source or target schema name ?
In our case we are just creating the missing indexes after the rehosting.
the source is : WCHILL. and the traget is : WCHILL the same
How did you create the missing indexes ?
The command to create missing index is already posted by you. You just have to execute it with DBA assistance.
Also, you can find the missing index using the PTC's utility: https://www.ptc.com/appserver/cs/view/solution.jsp?n=cs62804
Thanks, I look that
Pascal
Here's how to fix it :
execute these commands one after the other
impdp xxx/xxx@target SCHEMAS=%source_scheme% directory=TEST logfile=WTBACKUP_Oracle_imp.log dumpfile=test.DMP EXCLUDE=FUNCTIONAL_INDEX
impdp xxx/xxx@target SCHEMAS=%source_scheme% directory=TEST logfile=WTBACKUP_Oracle_imp_idx.log dumpfile=test.DMP INCLUDE=FUNCTIONAL_INDEX
Pascal
