Error check-in FamilyTables - windchill 8 - proE WF3
pvieira
3-Newcomer
Hi there! i'm a computer technic in a company and we use proEngineer , i dont understand so much about it , but i already solved a lot of problems in their usability . i like to know if exists some pdf for proE administrators like me!
But i created this question because i have a problem with a colleage checking-in a familyTable product.
Please, see if you can help-me i'm getting this error with FamilyTables when i make a check-in : Nested Exception: wt.util.WTException: Family Table Validations failed.
See image bellow please.
Best Regards !
Hi Pedro,
If this is a new family table you might want to make sure you validate all the instances in the family table. However, if this is an existing family table that is being modified, then you typically have to contact PTC with some diagnostic logs to get the error fixed.
Micah
