Hi All,
Am creatig webservices follwing WebServicesFramework guide and done with below steps
Generated TrustStore ad key store and made property changes accordingly
ant -Dproject.dir=<Windchill>/prog_examples/jws/MyProject -Dservlet.name=MathService -Dsecurity.policy=userNameAuthSymmetricKeys -Dservice.type.id=org.myorg.MathService -Dmain.class=org.myorg.MathClient -f bin/adminTools/WebServices/new-project.xml create
This created following directory structure
src/ :
src/build.xml:
src/tasks/org/myorg/MathService:
src_client/:
src_client/build.xml:
src_client/org/myorg/MathClient.java
Modified empty client code by setting credentials and compiled
% cd <Windchill>/prog_examples/jws/MyProject/src_client
% ant
Ending up with the error code 401 and i assume this is related to authentcation. And the version ofwindchill is 10.2 M020
Please share your insights.
