Hello ,
I have a setup installed with navigate 1.1 and windchill 10.1
Some IBA Values like version is not displaying completely like iteration are not displaying in it .
Also in PartListApp the table is not population sharing some of the logs of thingworx .
It would be great if anybody could help on the same .
Kind Regards ,
Amar
Features in Navigate have been added and improved since Navigate 1.1 was released. I encourage you to get the latest release (Navigate 1.6), and see whether that affects your issue. I realize that you may not have upgraded your Windchill yet and only Navigate 1.1 is compatible with Windchill 10.1, but the early unsupported versions were less capable than the current software.
