I am getting "CAD part XYZ.prt is not unique" error while checking in a particular assembly in Windchill.
In that assembly file there is no CAD part called as "XYZ.prt".
Is there any command to identify which part /feature / layer / subassembly is taking reference from this CAD part XYZ.prt?
or is there any other solution?
Saurabh
For more information and possible solutions you can look at a similar thread here
Is the part that you are checking in a new object? Can you post a snapshot of the checkin window?
Hi Manjunath,
Asm file does not have any sub part called as XYZ.prt.
Already in data base same named file is exists, so you may face this problem. if you are not able to see that part, contact admin who have full rights to Windchil
