Error while creating Context
KV_10756215
I am using PTC Pro/Intralink Release 11.1 and Datecode with CPS M020-CPS13
While creating a product, getting below error:
Type Identifier "WCTYPE|wt.change2.WTChangeReview|wt.change2.PeerReview" cannot be found. See the Windchill Business Administrator's Guide for further information.
Here are the errors that I faced
Make a new template and make the modifications in that template. Its just an XML file.
8 REPLIES 8
Followed PTC Article - CS391160, but issue still exists
Are you using a specific or custom product/library template? You can download that (its XML) and see if its looking for that object type. Does that object type exist in your Type Administrator at the site level?
I looked over the product template XML and its looking for the object type. On the Type and Attribute end, initially the type is not there but i created one and even after that as well, the issue persists.
The Peer Review object should exist in your system. The fact that its not is the issue. I do not think this is something you can just create. Noting you called this system Pro/Intralink 11.1. Intralink was retired long ago, you mean Windchill right?
https://www.ptc.com/en/support/article/CS394902?source=search - Possibly deleted by mistake?
You should be able to remove the ACLs in the product template xml and reupload so it does not called out a reference for this but I would be concerned at why this is missing in the first place.
Thanks for your inputs on this one. At the moment, we are unable to make any modifications on the product template. Do we really have an alternate way, without touching the existing templates and ensuring that we resolve this issue?
NOTE: This issue is with Intralink 11.1 only and not with Windchill PDMLink.
Hi @KV_10756215,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
HelesicPetr
(To:KV_10756215)
Hi @KV_10756215
@avillanueva is right, you have to recreate the context template where the review type object is not used anymore.
I remember that the Windchill Intralink 11.1 did not contain change processes. Only Promotion can be used for changing state.
PetrH
