We're using Windchill 10.2. As a part of upgrading to 11.0, we're testing it in a test environment. 3 servers are configured as following in the same order as listed below;
I'm also attaching the log files mentioned in the error. Please help identifying the cause of error.
Thank you
I found the resolution for the issue. It seems PSI doesn't go very well with Windows Servers Auto Admin Approval mode.
Even after turning off UAC, installation was generating this error. But together with turning off UAC, if policy setting "User Account Control: Run all administrators in Admin Approval Mode" is disabled, PSI works fine.
Did you close the error window before copying the log files? The log files are not closed until you hit OK in the error window.
Oops... No, I didn't. I did reset the VMs to start over again.
I received the error both times I tried before. Will try again and if I get the same error, I will copy the logs after closing the error window.
Hello BenLoosli,
It looks like the error is happening while creating/configuring either WC Install User account or WC App User account in Oracle. The reason for my conclusion is;
I am attaching the fresh ocu installation logs. Yes, I copied these files after closing the error popup.
Thank you
Further analysis shows the error being thrown immediately after the following setup started running.
..\MED-60419-CD-110_M030\OCU\Disk1\InstData\Windows\NoVM\setup.exe
Any idea why it would throw error?
Thanks.
Checked further. I think it has got something to do with Java. See below log lines from one of the PSI log files.
INFO 2018-04-07 21:33:52 - ###################################################
INFO 2018-04-07 21:33:52 - Running ocu Installer
DEBUG 2018-04-07 21:33:52 - calling executeInstaller(\\192.168.30.1\Windchill_v11.0\MED-60419-CD-110_M030\OCU)
DEBUG 2018-04-07 21:33:52 - Processing subinstaller assembly (ocu): timer.start
INFO 2018-04-07 21:33:52 - Running: C:\Windows\system32\cscript.exe //E:vbscript \\192.168.30.1\Windchill_v11.0\MED-60419-CD-110_M030\OCU\setup.vbs WAIT LAX_VM C:\Users\Svc.Windchill\AppData\Local\Temp\I1523119846\Windows\resource\jre\bin\java.exe -f D:\ptc\WC11\PSI\installer\PSITempProps\ocu-installer.properties -DMULTI_PROGRAM_EXEC=1
INFO 2018-04-07 21:34:50 - Completed: C:\Windows\system32\cscript.exe //E:vbscript \\192.168.30.1\Windchill_v11.0\MED-60419-CD-110_M030\OCU\setup.vbs WAIT LAX_VM C:\Users\Svc.Windchill\AppData\Local\Temp\I1523119846\Windows\resource\jre\bin\java.exe -f D:\ptc\WC11\PSI\installer\PSITempProps\ocu-installer.properties -DMULTI_PROGRAM_EXEC=1
INFO 2018-04-07 21:34:50 - return code = -1
============= start: ocu summary =============
ocu installer finished.
Return code: -1
One or more of the actions from the installation sequence caused a fatal error.
============= end: ocu summary =============
DEBUG 2018-04-07 21:34:50 - Installation is Aborting.
The following logs contain information that may be useful for diagnosing installation problems.
Please include them in your support requests.
D:\ptc\WC11\ocu\installer\logs\OCU_PtcInstall.log
D:\ptc\WC11\ocu\installer\logs\OCU_InstallLog.xml
FATAL 2018-04-07 21:38:15 - Aborting installation.
FATAL 2018-04-07 21:38:15 - Installation is Aborting.
FATAL 2018-04-07 21:38:15 - One or more of the actions from the installation sequence caused a fatal error.D:\ptc\WC11\ocu\installer\logs\OCU_PtcInstall.logD:\ptc\WC11\ocu\installer\logs\OCU_InstallLog.xml
FATAL 2018-04-07 21:38:15 - aborting: original exit_code = 2
