Experience with Queues
Highlighted
Newbie
does anyone have experience with (programming) Queues in Windchill? I want to add some entries to a queue and then process this entries. I am looking for an example e.g. in java, how to manage this. Any help is welcome, also additional documantions would be fine.
Best Regards
Stefan
5 REPLIES 5
Highlighted
RE: Experience with Queues
Hi Stefan,
Primarily there are two types of queues in Windchill, Processing Queue and Schedule Queue. Here is a snippet that will work with Processing Queue. Only requirement is that the method you are adding to queue should be public and static. Code for Schedule Queue also will be along the same lines.
ProcessingQueue processingQueue = (ProcessingQueue)QueueHelper.manager.getQueue("CustomQueue", wt.queue.ProcessingQueue.class);
Class aclass[] = {
wt.fc.ObjectIdentifier.class
Object aobj[] = {
objectIdentifier
wtprincipal = SessionHelper.manager.getAdministrator();
String CLASSNAME = (WorkflowUtilities.class).getName();
String methodName = "extractBOM";
processingQueue.addEntry(wtprincipal, , CLASSNAME,methodName, aclass, aobj);
Prathap
In Reply to:
Best Regards
Stefan
Highlighted
thanks for the code example. My problem for the moment is, that I have to start with queues, so as I understood, the first step is to add some entries into a queue. I have tried to add a string as parameter, but got an error, here is my code:
ProcessingQueue testQueue = (ProcessingQueue)QueueHelper.manager.getQueue("testQueue", wt.queue.ProcessingQueue.class);
WTPrincipal wtprincipal = SessionHelper.manager.getAdministrator();
String CLASSNAME = (com.sg.QueueTest.class).getName();
String methodName = "doJob";
Class aclass[] = { String.class };
Object aobj[] = { "my test string" };
testQueue.addEntry(wtprincipal, methodName, CLASSNAME, aclass, aobj);
The class and the method are also availabe on server, the method, which should process the job looks like:
public void doJob( String str ) {
System.out.println( "doing a job: " + str );
return; }
My prolem for the moment is, that adding the job throws the following exception, any idea what the problem is?
Regards
Stefan
008-07-30 10:38:51,856 ERROR [main] root - * Couldn't add entry to queue 'testQueue'
2008-07-30 10:38:51,856 ERROR [main] root - * Entry: com.sg.QueueTest.doJob
2008-07-30 10:38:51,856 ERROR [main] root - * Args: [Ljava.lang.Object;@95cfbe
2008-07-30 10:38:51,856 ERROR [main] root - * Exception:
2008-07-30 10:38:51,871 ERROR [main] root - (wt.pom.pomResource/0) wt.pom.POMInitException: A persistence error occurred. System message follows:
Nested exception is: wt.method.MethodServerException: No active method context
Exception in thread "main" (wt.pom.pomResource/0) wt.pom.POMInitException: A persistence error occurred. System message follows:
at wt.method.MethodContext.getContext(MethodContext.java:1150)
at wt.pom.PersistentObjectManager.getPom(PersistentObjectManager.java:277)
at wt.pom.Transaction.start(Transaction.java:441)
at wt.queue.ProcessingQueue.addEntry(ProcessingQueue.java:469)
at com.sg.QueueTest.doIt(QueueTest.java:77)
at com.sg.QueueTest.main(QueueTest.java:37)
Highlighted
Hi Stefan,
how are you running your code? from command line, from a JSP.... ?
Iker Mendiola
Prambanan IT Services
http://en.prambanan-it.com
Iker Mendiola
Highlighted
Hi Stephan,
Check the following conditions and see if any of them helps.
1. The method you are calling should be public and static.
2. Your 'testQueue' should already exist. It doesn't create one for you.
3. You need a method context to run this code. This code should be on the
server side(method server), typically run from Windchill Services.
Prathap
Highlighted
the code was running from client, now I changed to the server and now it works.
Regards
Stefan
