Export/Copy contents of a "Library" from Windchill 11.0 M030-CPS16 to 11.1 M020-CPS16
HJ_10071856
8-Gravel
Is there a way to export contents of a "Library" from Windchill 11.0 M030-CPS16 to  Windchill 11.1 M020-CPS16. Have already explored Export/Import utility (after setting : wt.ixb.import.allowCrossReleaseImport = true in wt.properties on Target Windchill), The Import activity results in following Exception:
Nested exception is: wt.pom.PersistenceException: The commit is mismatched. It corresponds to level "1". Current level is "0"
THE RESULT OF THE IMPORT :FAILED
Any thoughts ?
1. Article - "The RevisionLabelCleanserDT Windchill Diagnostic Utility task fails when run on a server that uses Oracle 12c": https://www.ptc.com/en/support/article/cs200625
2. Another solution: "Stop Windchill, clear the codebase\wt\workflow\expr workflow expressions cache folder, restart Windchill and monitor that the issue does not occur anymore".
