Export Organization
ailut
2-Explorer
Export Organization
Hi all,
Do you know if its possible to export the organization in Windchill 10.2?
Alex
satre-2
(To:ailut)
Alex,
Do you want to split one windchill installation with 2 or more organization into separate windchill installation? or you want to migrate one organization unit to other PLM system ?
Below are the several approached I used in past
  • Windchill bulk migrator is best tool to extract data for Extract data and migrate into other windchill. In staging database of WBM you can perform necessary data clean-up/normalization also,
  • If you have good knowledge about Windchill API’s then it would more simple to write custom java classes which will query and extract data from windchill.
  • OOTB you can use export and import manager to export data from windchill  (Context > utility > Export  Import Manager  )
Hope it helps  !!!
Shryeas
