Exporting assembly data to local drive from Windchill without adding to workspace
Vignesh_AJ_77
8-Gravel
Version: Windchill 12.1
Use Case: I need to export the assembly data with the children to local drive without opening it in Creo or without adding it to workspace.
Description:
I don't see any option to export from Windchill directly to local drive without adding the assembly to your workspace first. Is there anyway or tool or some method to export cad data from Windchill directly to your local drive?
Windchill 12,1
6 REPLIES 6
@HelesicPetr   Just checking, if you are aware about this. If possible, could you please advise. Appreciating your support. Thanks.
Hello @Vignesh_AJ_77
You can use two OOTB tools to do it.
1. Generate package of the assembly and then download a zip file from the package.
2. You can use in a Export/Import utility from context utilities menu.
PetrH
Hi @HelesicPetr , thank you for the response. Could you please advise if there is any document or answer where I can refer how to generate package of assembly and download as zip file?
Thanks.
Thank you so much. It helped,
It looks like you have some responses from a community champion. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
