Version: Windchill 12.1
Use Case: I need to export the assembly data with the children to local drive without opening it in Creo or without adding it to workspace.
Description:
I don't see any option to export from Windchill directly to local drive without adding the assembly to your workspace first. Is there anyway or tool or some method to export cad data from Windchill directly to your local drive?
Windchill 12,1
@HelesicPetr Just checking, if you are aware about this. If possible, could you please advise. Appreciating your support. Thanks.
Hello @Vignesh_AJ_77
You can use two OOTB tools to do it.
1. Generate package of the assembly and then download a zip file from the package.
2. You can use in a Export/Import utility from context utilities menu.
PetrH
