We are happy to announce the new Windchill Customization board! Learn more.
Expression to populate all users from a particular context role to a workflow variable
b211284
Hi All,
We have a workflow variable(wtuser) and a context role say designer.We initiate this workflow on every wtpart and want the variable to be populated with all the users from designer role from the particular context(Product) in which the part is added.
-Nilesh
Hi Nilesh, Try the following snippet and see if it helps. import
wt.part.WTPart;
import wt.part.WTPartMaster;
import wt.query.QuerySpec;
import wt.query.SearchCondition;
import wt.fc.QueryResult;
import wt.fc.PersistenceHelper;
import wt.project.Role;
import wt.inf.team.ContainerTeamHelper;
import wt.inf.team.ContainerTeam;
import wt.org.WTPrincipal;
import java.util.Vector;
String number="OEMPART1";
Class className = wt.part.WTPart.class;
String usersList=";
int[] index = new int[1];
index[0] = 0;
QuerySpec queryspec = new QuerySpec(className);
queryspec.appendWhere(new SearchCondition(className, "master>number", "=",
number), index);
queryspec.appendAnd();
SearchCondition(className,wt.vc.Iterated.LATEST_ITERATION,SearchCondition.IS_TRUE));
QueryResult queryresult = PersistenceHelper.manager.find(queryspec);
System.out.println("Result size :"+ queryresult.size());
while (queryresult.hasMoreElements()) {
Object obj = queryresult.nextElement();
if (obj instanceof WTPart) {
WTPart part = (WTPart) obj;
String displayIdentifier = part.getDisplayIdentifier();
System.out.println("Part :"+displayIdentifier);
System.out.println("Container "+ part.getContainer().getName());
Role designer = Role.toRole("DESIGNER");
System.out.println("Role "+designer.getDisplay());
ContainerTeam team
=ContainerTeamHelper.service.getContainerTeam(part.getContainer());
System.out.println("Team "+team.getDisplayIdentifier());
System.out.println("Roles "+team.getRoles());
System.out.println("Members "+team.getPrincipalTarget(designer).toString());
Enumeration designers = (team.getPrincipalTarget(designer));
System.out.println("designers "+designers);
while (designers!=null && designers.hasMoreElements()) {
WTPrincipal member = designers.nextElement();
System.out.println("Member :"+member);
usersList+=member.getName();
} Regards,
Prathap
