Failure in Import
DS_14152003
2-Explorer
Failure in Import
Version: Windchill 12.1
Use Case: Import preview started... Started object creation process... Object com.ptc.windchill.option.model.OptionMaster:5369119680, A exists with the UFID that is different than the UFID from XML THE RESULT OF THE IMPORT :FAILED
Description:
i have already tried resolve overridable conflicts but it didnot work out same issue again.
I even tried to locate but its referring to a ufid or some option which is not found on UI or in logs, getting same error in logs also
Can you add some detail like what you were importing and how?
