I am using Windchill Rest API and TwxIEWebService SOAP API. Using these APIs I am consuming CAD Documents and Change Request. But I am not getting any information of related part. Say Change Request "CR001" is related to Part "P0001", or CAD Document "CAD0001" is related to Part "P0002". How could I get the related Part information using REST or SOAP API?
Not sure what TwxIEWebService is but this will fetch your your affected objects in a JSON format given a CR
https://{HOST}/Windchill/servlet/odata/v3/ChangeMgmt/ChangeRequests('OR:wt.change2.WTChangeRequest2:{YOUROBID}')?$expand=AffectedObjects
It returns something like below
"AffectedObjects": [
"ChangeStatus": {
"Path": "https://{HOST}/Windchill/netmarkets/images/chg_pending9x9.gif",
"Tooltip": "Pending change exists"
"CreatedBy": "Some Name",
"CreatedOn": "2019-05-02T00:55:00Z",
"HasHangingChange": false,
"HasPendingChange": true,
"HasResultingChange": false,
"HasVariance": false,
"ID": "OR:wt.doc.WTDocument:54630",
"Identity": "Document name, 5.G",
"LastModified": "2019-05-08T23:27:11Z",
"Latest": true,
"LifeCycleTemplateName": "Lifecycle Name",
"Location": "/folder/location",
"ModifiedBy": "Some Name",
"Name": "Document name",
"Number": "1111111",
"ObjectType": "Subtype name",
"Revision": "5",
"State": {
"Value": "RELEASED",
"Display": "Released"
"TypeIcon": {
"Path": "https://{HOST}/Windchill/wt/clients/images/generic.gif",
"Tooltip": "Subtype"
"Version": "5.G",
"VersionID": "VR:wt.doc.WTDocument:38438"
"ChangeStatus": {
"Latest": true,
"Revision": "5",
"State": {
"TypeIcon": {
"Version": "5.G",
I am getting 404 Not Found error for "servlet/odata/v3" endpoint, but "servlet/rest" is working. Is there any configuration by which we can enable "odata" REST API?
I don't know when this was introduced, but we don't have it on windchill 1.1 REST Services but have it on windchill 1.6 REST Services. If you have it, it will show up here:
Got your point. We have Rest 1.1. We need to update it on Rest 1.6
