Is there a way to see the sizes of files within the Folder Contents table itself? Like to have it in between the Version and Last Modified columns?
Need to create a custom java DataUtility https://www.ptc.com/en/support/article?n=CS141887&language=en
e.g for data
com/ptc/windchill/enterprise/attachments/validators/AttachmentsValidationHelper.getPrimaryContentItem();
String sizeInKB = DataTypesUtility.toString(appData.getFileSizeKB(), locale);
e.g for data
