File vault Manual sync
spitchan
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020 CPS30
No of Cached files are not changed even after did a manual sync thru JConsole.
HelesicPetr
(To:spitchan)
Hi @spitchan
The cached files could be not referenced file anymore so the synchronization is not needed.
PetrH
5 REPLIES 5
Hi @spitchan
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
Andra
HelesicPetr
(To:spitchan)
Hi @spitchan
PetrH
spitchan
(To:HelesicPetr)
What does it mean by referenced files?..you mean referenced in any other Assembly ? We tried running the
Go to JConsole > wt.method.Method Server Main* MBeans > com.ptc > Monitors > Cache Vault Synch > Operation > SysForceSync.
But still the cached files are not reduced.
HelesicPetr
(To:spitchan)
Hi @spitchan
You could use delete unreferenced files.
PetrH
spitchan
(To:HelesicPetr)
Yes we deleted the unreferenced files and deleted the orphaned items thru SQL: scripts and we are able to decommission the server now
