Find Similar Parts window shows Parts for the nodes even if no attributes are defined for that node
abhishekarya
I am using Windchill PartsLink Release 11.1 and Datecode with CPS M020-CPS12
Find Similar Parts window shows Parts for the nodes even if no attributes are defined for that node, we are separating our attribute releases based on different nodes so we want to find the Parts only where the classification attributes are present but it looks like its searching for all the Parts, we don't want to see that windows for nodes which do not have any attributes
Hi abhushekarya,
This is Bhushan from PTC Technical Support.
I hope you're doing well.
I could reproduce the behavior locally, I suggest you to raise a case in order to investigate more and confirm if behavior works to specification or any bug.
Also refer to Help Center : Finding Similar Parts
Bhushan
Hi @abhishekarya,
Please let me know if we have any follow up queries, else we can move towards closure of this conversation as we need more investigation using a new PTC Technical Support case.
Bhushan
abhishekarya
(To:bhushan.d)
I'll open up a case thanks
