Finding original name of a renamed file
BenLoosli
Is there a method to find or have Windchill capture the original name of a
renamed file? If we create a part, 1000307.prt with number 1000307, use it in 10
assemblies and then decide to use the vendor's name. We rename 1000307.prt to
loc-246.prt with number LOC-246. The assemblies will load loc-246 instead of
1000307, so that is good. Now management wants to see which parts used 1000307.
As far as I can tell and get from Windchill is nothing if I search on 1000307.
If I know that the new number is loc-246, I can get the where used and show the
assemblies, but still no reference exists between 1000307 and loc-246. Is there
a table in Windchill that might have this information?
soerton
(To:BenLoosli)
You should be able to find the original name in the Rename History table (see attachment).
Stephen Oerton
Windchill Process Specialist
soerton
(To:BenLoosli)
We started with 10.1 and are on 10.2 M020 now. we created this tab called Additional History and added it from the customize drop down
Stephen Oerton
RandyJones
(To:BenLoosli)
Attached is a report that we use here. It allows you to search for the old cadname and will give you the new cadname. I think I actually originally recvd this report from someone on the exploder. Unfortunately I don't remember who it was to give them credit.
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
Randy,
I add your report in this document I wrote on PTC Community.
http://communities.ptc.com/docs/DOC-6348
It's very long and collect a lot of things I found here in the exploder, in the Community and also article from Tech Support.
Hope you can find it useful.
You can also join this group http://communities.ptc.com/groups/reporting and maybe vote up this two idea:
http://communities.ptc.com/ideas/4634
http://communities.ptc.com/ideas/4659
Marco
Marco
