That's it. I like it better than the old search because you can append as many results to the working session as you want instead of having to do separate searches, each with a separate results screen. It really isn't dissimilar from any of the collectors in PDMLink where you click to add something, search forwhat you might want, multiselect what you want, and then add those selections to your original screen. It is the same in the Groups section, too. Al AndersonSolar Turbines Incorporated
-----"Gerry Champoux" <-> wrote: -----
