Version: Windchill 12.0
Use Case: I design aerial platform with extendable arms. In Creo, I create flexible hoses and ropes with the piping module. I use a master model skeleton as the reference for all routing datums and features of the hose.
Description:
When I finish the model I check in it in windchill.
The flexible hoses, with the model in check in, are locked and don't move with the skeleton.
I want everyone to be able to consult the model with the correct movements.
Hi @MV_8487961,
Thank you for your question!
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
