Folder Location - Set as default
Amirtharaj_K
Hi Guys,
I am using multi CAD software example inventor, creo and solidworks, i am looking for once i create a Inventor 3D model it's stored particular folder and same like for other software's. How we can do it in Windchill.
Aj
8 REPLIES 8
Fadel
23-Emerald I
(To:Amirtharaj_K)
For widnchill , ones checked in they are all EPMdocs, to achieve your request , you need to edit the OIR as per https://www.ptc.com/en/support/article/CS21487
Fede
Hi Aj,
Interesting question
Windchill OOTB only possible at based on OIR object type (WT & CAD subtypes) you can change the default and specific folders location algorithm not for cad application wise
may be you can post this requirement ptc community  add tags windchilll customization
Thanks & Regard
Sarathkumar M
Sarathkumar M
In the workspace preferences, there are options to specify default folders. Assumingly, you would be operating in different workspaces for the difference CAD application types. This only applies for initial creation. Reading docs here: https://support.ptc.com/help/wnc/r12.0.2.0/en/#page/Windchill_Help_Center%2FCADxWspActionsMenuWspGenOptionSet.html%23wwID0EIILM
The OIR mentioned by @Fadel by default cannot differentiate between different CAD authoring applications but I would not remove hope that an if/then rule could be added to differ based on that attribute. It certainly would be more complex. I would also consider periodic sweeps and movements to keep system clean administratively. Users have the ability to overwrite anything you put in place.
Thanks for the replies guys,   @Fadel @Sarathkumar_M @avillanueva
WT part means we can do it us you said Fadel, But if it's CAD data such as Creo, Solidworks, NX, Catia and AutoCAD mean how we can set a default folder for that.
Sarath thanks for the update.
Avil, yeah as you said we can do it in workspace preferences, but we can set it on one machine only right? How can we apply the same thing to all the machines like Visualization Services Administration?
AJ
Dobi
(To:Amirtharaj_K)
Your non-Creo data needs to have the "UPLOAD_SOFT_TYPE" variable set. You set it by CAD application in Preferences. (CS41665 )
You can then create individual EPMDocument sub-types to match your authoring applications (instructions here).
In my example, I did this for NX.
Once you have those, you create OIRs against those subtypes specifically with the OIR syntax:
  • <AttributeValues objType="wt.epm.EPMDocument|<your subtype name here>">
And in the OIRs you can then specify the folder like @mfadil suggested (CS21487).
Amirtharaj_K
(To:Dobi)
Apologize for the delayed in reponse @Dobi
I want more details which you shared - OIR Example.
AJ
Dobi
(To:Amirtharaj_K)
CS21487 goes over this in good detail for the OIR.
If you create a soft-type for, say, NX and have a folder in Commonspace for NX, the OIR would look something like this - including just the folder tags. Your NX folder has to exist and your softtype name needs to match whatever the internal name you used in the set up in type attributes.
<AttributeValues objType="wt.epm.EPMDocument|com.someCompany.www.NXSoftType">
  <AttrValue id="folder.id"
    algorithm="com.ptc.core.foundation.folder.server.impl.FolderPathAttributeAlgorithm"
    ignore="false"
    force="false"
    final="false">
    <Arg>/Default/NX</Arg>
  </AttrValue>
<AttrConstraint id="folder.id" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
	<Value algorithm="com.ptc.core.rule.server.impl.GetServerPreGeneratedValue"/>
	<Value algorithm="com.ptc.core.rule.server.impl.GetRendererConstraint">
		<Arg>SelectGeneratedFolderByDefault</Arg>
	</Value>
</AttrConstraint>
</AttributeValues>
Hello @Amirtharaj_K
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
