Dear all
I have had folder replication to a remote site working for a while now. The disk on the target machine filled up and the desision was taken to get a faster PC with more storage, The IP was swapped from the original PC, the fileserver was installed and the vaults moved to the same path. Now the replication will not work (it also no longer works if we put the original PC back on under it's original IP)
I can ping the remote server, I can create new file vaults, i have check port 7777, I can query file vault space from the DSMU so to me it seems we have network connectivity. I have even tried purging the replicated files and starting again but I get similar error messages when purging.
Below is the error I get when replicating using both the gui and the command line
Error Stack:
Error 411 [module 1] (Error): <no message=">
Error 408 [module 1] (Error): <no message=">
Argument 1:
frl-ilnk-fs:7777:d:\frl\vaults\msd\20060904|391969.prt
Argument 2:
192.168.0.72:7777:c:\frl_vault|1033211.prt
Error : Connection Error/TimeOut
Argument 1:
frl-ilnk-fs:7777:d:\frl\vaults\msd\20060904|375589.prt
Argument 2:
192.168.0.72:7777:c:\frl_vault|1033210.prt
Argument 1:
frl-ilnk-fs:7777:d:\frl\vaults\msd\20060904|375588.prt
Argument 2:
192.168.0.72:7777:c:\frl_vault|1033209.prt
Error 48: No connection to remote host established
Argument 3: 408
I would grateful for some ideas on what else to try.
