When I search for a WT part where used in all the BOM structures in Windchill, the results area shows the data with columns 'Number', ''Version'', ''Name'', ''Context''. Can I get the End Item Tag for the Wt part where the searched part is used. The results can be exported to excel and the End Items can be used for the ECN. Attached is example.
Hello @KSHITISH_S
If you need to just add the column follow the instructions in following thread How-to-Customize-where-used-panel
Hope this can help.
PetrH
Hello @KSHITISH_S
Hope this can help.
PetrH
