Your summary is right.
IBA on EPMDocument type. The same IBA name should be mentioned under preference Operation > Auto Associate > Phantom Assembly Override Attribute Name to a BOOLEAN customer-defined soft attribute
If you are planning to drive the value from CAD Application, then one additional step of including PARAMETER (CAD Applications) name for EPMDocument IBA definition.
Hi @HJ1
Thank you for your post.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
thank you for the confirmation.
The Help Center text is a bit confusing also with the preference name including "Phantom" which is used elsewhere to something else...
We keep CAD and WTPart in the same revision so driving Gathering Part from CAD probably wouldn't work.
