We have a requirement to generate BOM from AutoCAD drawing. In the drawing the designers put BOM details (Part Number, Drscription etc) using blocks in AutoCAD. I can import the drawing using WGM for AutoCAD but I will not be able to generate BOM using part details mentioned in the drawing blocks.
Is there any way to generate BOM by reading the block details while checkin the drawing?
Please suggest
Sitanshu
Hi
I do not know that way but what about another way.
The BOM is first created in PDMLink (using WTpart) and then the users upload the autocad drawings into the corresponding WTpart.
I guess this could be OK for new drawings but for legacy data....
Also Windchill has a Workgroup CAD Manager for autocad. have you tried this, this should then work more like when you have ProE integrated and the BOM should be created automatically on check in
