Hi all,
Is there a way or is it possible to create a report that will generate who checkin/checkout the documents? Or how many times that the documents checked in/ checked out?
Luar
Luar,
take a look at this article I wrote Resource for reporting
There are many useful things and also links to a lot of query builder report.
Hi Marco,
That was useful thanks, but I cant log in to http://portal.ptcuser.org/ I enter the same user and pass here in ptc but it is invalid. ![]()
Hi Luar,
to log into PTC/User you have to register because, at the moment, PTC account is useless.
Is there any tutorial how to generate a report using query builder?
Thanks!
I want to generate report with a date range but I don't know what attribute that I'm going to use. To generate a report that shows all of the drawings within the specific date range.
The FF. is the attribute that I used but there is no date range it only just show all the Report that lists the size of CAD Documents.
Bset Regards,
Luar
This article provides an example of how to do a date range in Query Builder:
http://support.ptc.com/appserver/cs/view/solution.jsp?n=CS153996
