Generating Reports
Luar
Generating Reports
Hi all,
Is there a way or is it possible to create a report that will generate who checkin/checkout the documents? Or how many times that the documents checked in/ checked out?
Luar
6 REPLIES 6
Marco_Tosin
(To:Luar)
Luar,
take a look at this article I wrote Resource for reporting
There are many useful things and also links to a lot of query builder report.
Marco
Hi Marco,
That was useful thanks, but I cant log in to http://portal.ptcuser.org/ I enter the same user and pass here in ptc but it is invalid.
Marco_Tosin
(To:Luar)
Hi Luar,
to log into PTC/User you have to register because, at the moment, PTC account is useless.
Marco
Luar
(To:Luar)
Is there any tutorial how to generate a report using query builder?
Thanks!
Luar
(To:Luar)
I want to generate report with a date range but I don't know what attribute that I'm going to use. To generate a report that shows all of the drawings within the specific date range.
The FF. is the attribute that I used but there is no date range it only just show all the Report that lists the size of CAD Documents.
Bset Regards,
Luar
LoriSood
23-Emerald I
(To:Luar)
This article provides an example of how to do a date range in Query Builder:
http://support.ptc.com/appserver/cs/view/solution.jsp?n=CS153996
