Generic is earlier than Instance
IanW
Version: Windchill 12.1
Use Case: I have a Family Table that an Instance that is at a later date than the Generic.
Description:
I have a Family Table that an Instance that is at a later date than the Generic.  I am not able to update the FT to bring both the instance and Generic to the latest iteration together.  How can I fix this FT?
The -.52 Generic references the -.2 instance.
The -.51 Generic references the -.3 instance.
BenLoosli
(To:IanW)
Do you have Windchill rights to check-out an older iteration? If so, check-out the -51 iteration and then check it back in as -53 iteration.
Rule of thumb for family tables is to never delete an instance. Mark it as obsolete or something, but do not delete it.
All of my hardware family tables are in a part library and only the system admins can modify them. These files are also set so the come into a normal workspace as read-only so the designers cannot screw them up.
BenLoosli
(To:IanW)
IanW
(To:BenLoosli)
Thank you, it worked as long as I checked out the instance that was out of date along with the generic.
