Get WTLibrary subfolder
VasiliyRepecki
Hi.
How can i get all subfolders for given WTLibrary or get subfolder by its name by java code?
I can not see any useful methods at FolderHelper. Should i use QuerySpec for my problem?
Thanks.
Going from memory here, but I think you need to start with the Cabinet when trying to get a Folder/SubFolder by name. The cabinet name is most likely "DEFAULT" (I think), so you could go about it a number of ways, depending on what exactly you want to do.
WTLibrary library = .....
WTContainerRef cr;
Folder f;
Cabinet c;
QueryResult qr;
SubFolder sf;
cr = WTContainerRef.newWTContainerRef(library);
f = FolderHelper.service.getFolder("/DEFAULT/FolderA/Folder1");
c = FolderHelper.service.getFolder("/DEFAULT");
qr = FolderHelper.service.findSubFolders((Folder)c);
while(qr.hasMoreElements()) {
sf = (SubFolder)qr.nextElement();
Or maybe if you want all folders inside the container at once? This may work, though I'm not really sure.
QuerySpec qs = new QuerySpec(SubFolder.class);
qs.appendWhere(new SearchCondition(SubFolder.class,SubFolder.CONTAINER_REF + ".key",SearchCondition.EQUAL,PersistenceHelper.getObjectIdentifier(library)),new int[]{0});
//WTAttributeNameIfc has something that should probably be referenced for ".key" and ".id" stuff instead of always hardcoding them.
qr = PersistenceHelper.manager.find(qs);
I have wt.folder.FolderNotFoundException for "/DEFAULT"
Try "/Default"
If that's no good, try the QuerySpec option and debug. There may also be a preference to show cabinets in the UI?
Matthew Knight, thanks a lot.
Default works!
