At the end of our ECN process I'd like to add additional information to the email notification. I've already done this for the Promotion Process, where I list out all the Parts, Documents and CAD Docs that have changed including their number, revision and name. and also a list of all the approver/reviewers comments.
I'd like to be able to get similar information into the email notification for the ECN Process. First piece that I want to tackle is the list of ECN resulting objects. I think I would use the following
QueryResult queryresult = ChangeHelper2.service.getChangeablesAfter(wt.change2.WTChangeOrder2);
And then iterate through the QueryResult to build my strings to output to the email body.
Has anybody anything similar and have some code snippets to share?
Steve D.
Thanks to Dax and Dave for verifying that I was on the right path... Below is some of the code I used to summarize the parts for the completed ECN
String myPartsList =";
String myDocsList =";
String myCadList =";
String myList =";
Integer iParts = 0;Integer iDocs = 0;
Integer iCad = 0;
wt.fc.QueryResult queryresult = wt.change2.ChangeHelper2.service.getChangeablesAfter( (wt.change2.ChangeOrderIfc) primaryBusinessObject);
//wt.maturity.PromotionNotice pn = ((wt.maturity.PromotionNotice)primaryBusinessObject);
//wt.fc.QueryResult queryresult = wt.maturity.MaturityHelper.service.getPromotionTargets(pn);
while (queryresult.hasMoreElements()){
wt.fc.WTObject obj = (wt.fc.WTObject) queryresult.nextElement();
if (obj instanceof wt.part.WTPart){
iParts ++;
myPartsList+=((wt.part.WTPart)obj).getNumber() + " - ";
wt.vc.Versioned verobj = (wt.vc.Versioned) obj;myPartsList+= "rev" + wt.vc.VersionControlHelper.getVersionIdentifier(verobj).getValue();
myPartsList+= " - " + ((wt.part.WTPart)obj).getName() + "\n";
} else if (obj instanceof wt.doc.WTDocument){iDocs ++;
myDocsList+=((wt.doc.WTDocument)obj).getNumber() + " - ";
wt.vc.Versioned verobj = (wt.vc.Versioned) obj;myDocsList+= "rev" + wt.vc.VersionControlHelper.getVersionIdentifier(verobj).getValue();
myDocsList += " - " + ((wt.doc.WTDocument)obj).getName() + "\n";
} else if (obj instanceof wt.epm.EPMDocument){iCad ++;
myCadList+=((wt.epm.EPMDocument)obj).getNumber() + " - ";
wt.vc.Versioned verobj = (wt.vc.Versioned) obj;myCadList+= "rev" + wt.vc.VersionControlHelper.getVersionIdentifier(verobj).getValue();
myCadList+= " - " + ((wt.epm.EPMDocument)obj).getName() + "\n";
if (iParts > 0) {myList += "Parts\n---------------------\n" + myPartsList + "\n\n";
if (iDocs > 0) {myList += "Documents\n---------------------\n" + myDocsList + "\n\n";
if (iCad > 0) {myList += "CAD Files\n---------------------\n" + myCadList + "\n\n";
summaryOfItems=myList;
