Hello friends,
I am setting my Distribution as it is working fine for me currently with Windchill 11 but it is not sending inflammations of Alternate parts along with the main part to my PLM connector.
While setting Distribution target information manually from 'Manage Distribution' from Site->Utilities, i am getting this error on clicking the 'Yes'.
Screen shot of an error has been attached with this discussion.
Kindly help me to set up the parameters here so that i can work in it.
Sunil Chauhan
Hi @schauhan & @deepakseth,
This seems expected behaviour if there are pending transactions or unresolved failure tasks. If this is the case ESI Services prevents modification of Distribution Targets.
To make it work you may try below steps:
I hope this will help you.
Shirish
I am having the same issue. Any solution for this please ?
Thanks in Advance .
Shirish
