Golf_CART Product doesn't shows any documents and WC parts ?
Pratik_More
Hi Experts,
I am just wondering is there any data inside the GOLF_CART product?
I have installed the WC 13 successfully with demo and all other data load conditions are checked during the installation. Installation was successful but I haven't check GOLF_CART product.
Now I can see it doesn't show up any demo data?
No CAD documents and No WC parts etc   Can someone confirm it the GOLF_CART is having any data when we load a demo Data during the installation.
or If I have missed anything or any sort of issue which can cause this?
It will be great help if get any suggestions on this as we are bit stuck here ...
Feel free to leave comment if I have missed anything...
Thanks in Advance.
Fadel
23-Emerald I
(To:Pratik_More)
issue tarcked in TS CASE 17831424
Fede
11 REPLIES 11
Fadel
23-Emerald I
(To:Pratik_More)
The golf cart should have some data :
you can try to reload the demo data manually , maybe something went wrong during installation .
Fede
Pratik_More
(To:Fadel)
 I did tried the manual upload it says its complete but doesn't show up in the Windchill. check below images...any other suggestion so far, I recall there was no error...and sadly other Product like "Drive Systems" and other shows the data only issue with GOLF_CART...
Fadel
23-Emerald I
(To:Pratik_More)
Do you see any errors in MS either during load or when accessing the loaded product ?
is this specific to Golf_Cart do you see data for Drive System ?
Fede
Pratik_More
(To:Fadel)
I can see data inside the Drive systems. issues was only with the GOLF KART. No errors as such...is there any place where we can check logs...
Fadel
23-Emerald I
(To:Pratik_More)
You can do that from UI :
as wcadmin go to Site>Utilities>Server Status> Monitoring tools> log File viewer and check below 2 options in yellow :
and look for Methodserverxxxx.log
Fede
BenLoosli
(To:Pratik_More)
I have always thought the Golf_Cart demo was product structure only, no CAD files.
I was going to say that too. There were representations loaded but you cannot load CAD from ImportfromFile methods.
Fadel
23-Emerald I
(To:avillanueva)
The issue looks more permission issue , even the 2 OOTB folders Design and manufacturing are missing on the screenshot
Fede
Fadel
23-Emerald I
(To:Pratik_More)
Fede
Pratik_More
(To:Fadel)
Hi Fedel,
I am still in discussion with PTC but no solution on this yet. We did try below solution but no luck
1.Manually data upload
2.Copying the Golf kart folder from other server where it looks fine and rerunning the loading demo data. Physical files are present inside the gold kart folder on system but unfortunately, it's not visible or loaded to the WC. No success yet.
3. We tired clearing the Chache but no luck so far
PTC support team is working on it and solution is still awaiting.
Fadel
23-Emerald I
(To:Pratik_More)
I'm working internally with the colleague owning the TS case , this a community board with no guarantee to have a resolution .
On the TS Case ,we can at a point involve R&D and get a resolution as WC13 is supported .
Fede
