Hi Guys,
I have got an error while installing Windchill 11 on Windows 7 OS. I have attached the screen shots of the error i got after clicking 'Install' button again and again. Kindly help me to get resolved it so that i can install the software easily on my PC.
Kindly review my attached screen shots and log files for an error.
Sunil Chauhan
Set SQLNET.AUTHENTICATION_SERVICES to "NONE" in the sqlnet.ora file?
By default the property SQLNET.AUTHENTICATION_SERVICES is set to "NTS".
Here i am using Oracle as database and i have set already as per the requirement into tnsnames.ora file.
I have started it's required Listener and and it maintains entry into tnsnames.ora file.
but since, got the error shown above.
Try to set SQLNET.AUTHENTICATION_SERVICES = (NONE) in the sqlnet.ora client file )
I have set it: SQLNET.AUTHENTICATION_SERVICES = (NONE) in the sqlnet.ora client file.
But still the same issue is there. Kindly help me to install it.
What version Oracle did you install?
Oracle 11g (11.2.0) and Windchill 11
I have Successfully installed Oracle database 11g Enterprise edition release 11.2.0.1.0 - 64 bit.
And I am trying to install Windchill 11.0 on OS Windows 7 Enterprise 6.1.7601 Service Pack 1 Build 7601 version.
The Windchill installer is sensitive to Oracle release, need use the release 11.2.0.4
Got Installed now. Thanks guys for your help.
