Group By This Field option in Workspace to group the objects by specific column
A.Krehl_6674
7-Bedrock
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.13
In commonspace there is a possibility to use the option "Group By This Field" of most of existing columns.
This option is not available in Workspace either on server-site or local workspace (Workgroup Manager).
Is there a reason or restriction why this is not available?
Fadel
23-Emerald I
(To:A.Krehl_6674)
There is already an Idea to change this fact https://community.ptc.com/t5/Windchill-Ideas/Add-Group-By-This-Field-and-Show-in-Groups-to-Workspace-Tables/idc-p/788123#M14774%3Fsource=search
for the reason , I think it is the technology used the folder view is JCA based n while the workspace  is a form porcessor
Fede
Hello AKrehl_6674,
Will you need further information here?
KR,
Charles.
Hello Charles,
for me it is not clear if this is a technical restriction and can't be implemented?
I see also the existing Idea which was closed because of less votes.
Makes it sence to create a new Idea based on this topic with the hope that this function can be implemented?
Andreas
Hi @A.Krehl_6674
Yes create the Idea.
PetrH
