Has any did the bulk load method to obsolete existing WTDocuments?
tchao
We are in need to obsolete a bunch of existing WTDocuments.  I have done creating new WTDocument using Bulk Upload method, but I have not done Obsolete existing WTDocument before.  Has anyone done this before?  If yes, can you share the xml recipe file if you can?
Thank you,
tchao
(To:tchao)
This xml file is working, but just that I need to change from this line:
<csvDocument handler="wt.doc.LoadDoc.createGeneral" >
to this line to get it working:
<csvDocument handler="wt.doc.LoadDoc.beginCreateWTDocument" >
The first one gave me and error and the change works and obsoletes the WTDocument.
Thank you.  I will create a recipe file for it.
HelesicPetr
(To:tchao)
Hi @tchao
In your XML you need to define lifecyclestate element where you set a obsolete state. The value is internal name of the state.
Also during the import/creation user needs to have a rights to modify that state, for example as a administrator.
<?xml version="1.0" ?><!DOCTYPE NmLoader SYSTEM "standardX20.dtd">
<NmLoader>
    <csvuser></csvuser>
    <csvname>DOCUMENT123.pdf</csvname>
    <csvtitle>DOCUMENT123.pdf</csvtitle>
    <csvnumber>DOCUMENT123.pdf</csvnumber>
    <csvtype>Document</csvtype>
    <csvdescription></csvdescription>
    <csvdepartment>DESIGN</csvdepartment>
    <csvsaveIn>/Default/Test_import/</csvsaveIn>
    <csvteamTemplate></csvteamTemplate>
    <csvdomain></csvdomain>
    <csvlifecycletemplate>Two Phase Development</csvlifecycletemplate>
    <csvlifecyclestate>OBSOLETE</csvlifecyclestate>
    <csvtypedef>com.ptc.ReferenceDocument</csvtypedef>
    <csvprimarycontenttype>ApplicationData</csvprimarycontenttype>
    <csvpath>D:\\fileContent.pdf</csvpath>
    <csvformat></csvformat>
    <csvcontdesc></csvcontdesc>
    <csvversion>A</csvversion>
    <csviteration></csviteration>
    <csvsecurityLabels></csvsecurityLabels>
</csvDocument>
</NmLoader>
PetrH
Thank you.  I will give this a try and let you know how it goes.
tchao
(To:tchao)
HelesicPetr
(To:tchao)
Hi @tchao
This is second handler method that can import WTDocuments.
based on csvmapfile.txt you can use both handlers and the wt.doc.LoadDoc.createGenera has to work.
It may be trouble with other elements that were not filed or what ever. MethodServer log should answer what was wrong.
Iam glad that I could help.
PS> my example uses "standardX20.dtd" but in windchill 12+ newer standard exists "standardX26.dtd""
PetrH
