Take a look at this article
Report to list all EPM Documents without representations
You can also look up what you asked for in the PTC Support KB.
https://www.ptc.com/en/support
You may also read this page
ptc.com/en/support/wnc-reporting-landing/wnc-reporting-landing-main
Hi Marco,
Thank you for sharing the links. But my requirement is for WTParts with no representation. I tried to use the same logic and criteria that is used for EPM in the link for my requirement, but the report is pulling the WTParts with and without representation.
Anyway thank you for your time.
Regards
Anil
Try to use this report and a sub select like the one in the EPMDoc report
Query Builder report to display WTParts having representations in Windchill PDMLink
And also this article could help
Hi Anil,,
Have you tried creating a publish scheduler job. Refer the steps mentioned in CS338535.
Let us know if that helps.
regards
~Syed
Hello Syed,
I have tried this before to get the report from WVS JOB SCHEDULER but it is giving results in below format shown in the image. It is very difficult to get the columns like container name, Latest iteration/version. this did not helped me.
Thank you for your time.
Regards
Anil
