Hide an attribute on layout customization?
Newbie
Hello everyone,
I have to hide an attribute on a layout when another attribute change the value.
for exemple :
Attribute A : boolean
Attribue B : String
If attribute A is false, Attribute B is hidden on the layout.
A.B
Re: Hide an attribute on layout customization?
I think you can't hide attribute, but you can make Attribute 2 not editable thanks Data Utility.
Thanks for you reply
I found out a method preValidateAttribute in DefaultUIComponentValidator, i found no documentation about that. But i will try to use this validator on my attribute.
Hi Anas Bennis‌,
It is ok if we make second attribute non-editable on editable and it depends on first attribute value we select?
For example:
I remember I had done something like this in recent past. If that is ok for you I can again give it a try and share my findings.
Shirish
