Hide non-latest References in Related Objects of EPM Documents
CHENAMA
Dear Community,
When we create any reference in EPM Documents, let's say we reference Part A in Drawing B and check-in both objects, we can see the reference in the related objects tab in Windchill. So far so good. When we now iterate Drawing B and replace Part A with Part B, we can still see the reference in Part A to the older iteration of the drawing. Which is technically true, but quite confusing for the users, as they just removed this reference.
Do you know if there any option to only show latest versions of refernces (similar to the where used tab for WT-Parts)?
Thanks in advance for any answer or hint and BR
CHENAMA
avillanueva
23-Emerald I
(To:CHENAMA)
Its beyond technically correct, it is truly correct. Its reflecting that the reference to the drawing is to that iteration and not the latest iteration or it would have shown the latest. The only want you can not reflect that is to purge the drawing history which will remove those earlier iterations.  This references table does not have any filtering options.
avillanueva
23-Emerald I
(To:CHENAMA)
