How can I Delete latest iterations for many objects together?
rratti
2-Explorer
6 REPLIES 6
ChrisPLM
(To:rratti)
if you have the necessary permissions to delete, you can search for those objects, select them and delete.
This will delete the latest iterations.
Sometimes, Windchill will ask you what type of delete you want to do.   Delete latest iteration, delete all iteration of selected revision etc....
Best regards
rratti
2-Explorer
(To:ChrisPLM)
I have the necessary permissions to delete, but if I search for those objects, select them and delete, this deletes the not only latest iterations.
Windchill asks me what type of delete I want to do, only if I select one item.
PTC says the following:
- The deletion of latest iteration of multiple objects is not possible.
- The only way is to delete the latest iteration of each object one at a time.
Best regards
ChrisPLM
(To:rratti)
Hi
now you are saying this. yes it deletes the latest revision and not the latest iteration. Sorry.
I see only one way to create a script that will read the number of the concerned object and delete the latest iteration.
rratti
2-Explorer
(To:ChrisPLM)
I just received the answer by PTC, thanks anyaway, I'm resolving in another way.
ChrisPLM
(To:rratti)
How ?
rratti
2-Explorer
(To:ChrisPLM)
Making a Mass change to enter an item deleted in many structures by mistake
