Greetings Windchill Gurus,
I have been working with a Windchill instance that was implemented long before I came on board. There has been many changes made to the system from OOTB. Now I am cleaning up all the Access Controls.
Can someone tell me if there is any documentation of the OOTB ACLs available?
Using Windchill 10.2 m030
Thanks in advance,
Cam
The majority of "OOTB ACL's" are in product/library templates - so this leaves only a few at Site and Org to find.
Might be easiest to install Windchill (could be on a laptop) for OOTB reference - we always keep at least one OOTB install just for this purpose.
Hi Cam,
If you search the Windchill Help Center for Context Policies you should see a section on Installed Site Context Policies.
Rob
