How can I increase the size of the "Find Participants" window?
岡武_12701680
2-Explorer
I am using Windchill PDMLink Release N/A and Datecode with CPS N/A
新規変更プロセスで「参加者を設定」の「参加者を検索」ウィンドウのサイズを大きくする方法を教えてください。
今のウィンドウのサイズだと、”役割に割当”の選択プルダウンが表示範囲になく見落としてしまうため。
How can I increase the size of the "Find Participants" window in the "Set Participants" section of the New Change process?
With the current window size, the "Assign to Role" selection pull-down is not in the display area and is missed.
6 REPLIES 6
Please provide some screen shots to illustration what you are seeing so its clear.
Thank you for your comment.
Window1 is the first window you open.
The one you manually expand will be Window2.
I would like to open it as Window2 from the beginning.
Window1
 window2
Are you using groups or individual names?
Grouping some names may shorten the list.
com.ptc.netmarkets.userSearch.maxCount is set to 50 as default
Thank you all very much.
Self resolved.
