How can i create REST web service into Windchill
abennis
2-Guest
Hello everyone,
I'm windchill beginner, and i want to create WebApp out of Windchill, that will call for Windchill services (ex : ReportTemplateHelper.generateReport() )
So, for me, to do that, i need to create RestFull web service into windchill, that will call for Windchill services. And out of windchill call my Rest services.
It is possible to do that? How can i create RestFull web service into windchill? it is possible to call this services out of Windchill?
Thanks!
asingh
(To:abennis)
Hi Anas,
It is very much possible to write web services in Windchill, Windchill comes with OOTB web service framework(JAX-WS(SOAP) based), using which you can easily develop and publish Java or Info* Engine based WSDLs.
You can refer to Windchill Info* Engine guide.
Do you specifically want to make use of RESTFUL API based web services?
I have published many JAX-WS(SOAP) based WSDLs in Windchill.
Aditya
Thanks for responding!
Yes i want to make use of RESTFUL API based WS, and i thing it's possible to do that in Windchill 10.2. This, despite that i didn't found any document referencing to that. if i found the solution i will share it with you
Anas
asingh
(To:abennis)
Hi Anas,
Please refer to the link below :-
https://support.ptc.com/WCMS/files/169111/en/IEUsersGuide.pdf
this guide has couple of chapters on web services(SOAP based).
thanks,
Aditya
