How do I export windchill usernames?
JH_10735852
2-Explorer
I am looking for a way to export all the usernames in the windchill system. Ultimately the goal probably will be to import those names into an excel spreadsheet. Any suggestions?
Hi @JH_10735852
Use the query builder (Report Manager)
Create new report with wt.org.WTUser type and select what you need.
PS> the results can be exported to a excel
PetrH
Hi @JH_10735852
PetrH
If you are on WC 12 .0 or newer, you can export directly from the members table of a group (if you have a group with everyone in it)
Take a look at this CS Article, maybe you can add the button where you want it?
https://www.ptc.com/en/support/article/CS172939
@HelesicPetr  Thanks for the response. This is really worked well for me.
