I am looking for a way to export all the usernames in the windchill system. Ultimately the goal probably will be to import those names into an excel spreadsheet. Any suggestions?
Hi @JH_10735852
Use the query builder (Report Manager)
Create new report with wt.org.WTUser type and select what you need.
PS> the results can be exported to a excel
PetrH
Hi @JH_10735852
PetrH
These are good point to start working on reporting
https://www.ptc.com/en/support/wnc-reporting-landing/wnc-reporting-landing-main/
[Knowledge Hub] Windchill PLM - Business Reporting(WBR)
Below some report already available on users
Report which lists the user with its associated profile
Report to list all the Users in Organization
If you are on WC 12 .0 or newer, you can export directly from the members table of a group (if you have a group with everyone in it)
Take a look at this CS Article, maybe you can add the button where you want it?
@HelesicPetr Thanks for the response. This is really worked well for me.
